Choosing which frame to start imported movie on in ASP10?
tempest1
Post by tempest1 »
Hi everyone,
I'm importing an external video to serve as an effect, so I've used import movie, I've removed the alpha layer and everything is all good... except that I'm having trouble finding how to have it not immediately play on frame 1. Anyone have any experience with this that can give me a hand? Or is it not possible?
Thanks for any help!
Rafa
Re: Choosing which frame to start imported movie on in ASP10
Post by Rafa »
I believe a simple solution would be to set the visibility of the layer to off and then on again at the desired frame.
tempest1
Post by tempest1 »
That'd be a good idea, but I'm not sure how to do that. How do you affect layer visibility in relation to keyframes? I've never been able to have anything to do with layers change on a keyframe... whatever I stick them at seems to apply for the entire animation?
neeters_guy
Post by neeters_guy »
You should be able move the clip along the timeline by clicking the Sequencer tab in the timeline.
tempest1
Post by tempest1 »
Okay! Thanks so much for the help!
tempest1 wrote:That'd be a good idea, but I'm not sure how to do that. How do you affect layer visibility in relation to keyframes? I've never been able to have anything to do with layers change on a keyframe... whatever I stick them at seems to apply for the entire animation?
"Enable animated effects" in the layer settings.
