I've been trying to render out a short animation,  I'm using PNG's with transparency and some vectors, but i am noticing some white lines appearing in certain parts of the images after exporting. They just appear randomly, I've exported as uncompressed AVI and also Quicktime and they both display the same issue.
Does anyone know how to easily fix this or is it a bug in the software? It looks fine in AS itself, it's only when i export and play the video that the glitches show up.
						White lines (graphic glitch) randomly appear.
				Welsh Jester
Re: White lines (graphic glitch) randomly appear.
Could you show us an example image, and can you replicate it with another file?
				Welsh Jester
i was mucking around with some image files to see what would make the problem appear, but i was only able to notice the issue with 2 files i have that are just basic cut outs of peoples heads.
Here's a simple example video of the issue i am talking about though
http://www.fileconvoy.com/dfl.php?id=ge ... 025382f44a
The flickers of white lines like breaks appear in different spots of the image.
Let me know what you think the issue could be and if there's a way to fix it, thank you.
				EHEBrandon
I'm having issues with this to... I get white lines or dots in my renders on my characters sometimes and I don't know why...
				Welsh Jester
Well after doing further renders it appears the cause of the graphic glitches might be in the 32 bit version, I've rendered out a few times in 64 bit and have not seen any odd glitches yet.
Only thing is there is no Quicktime export in 64 bit.. I've had to use Xvid which produces bigger files but works, i tried with x264 and videos won't render properly and come out poorly synced/laggy unless i did something wrong.
Might be codec related, have You tried Quicktime Altrnative with Anime Studio, might solve your problem!
