"Sketchy" Stroke option question (Black only??)
ThatsNotAllFolks
Post by ThatsNotAllFolks »
I have only been able to get the sketchy stroke option to render in black color. No matter what color I am using in the palette, it always renders in Black. Is there a way to get the sketchy stroke render option to render other colors besides black.
Thankyou
Re: "Sketchy" Stroke option question (Black only??)
No problem getting any color sketchy strokes here, on 10.1.
ThatsNotAllFolks
This one is still a mystery for me. I just updated to version 10.1.1 and I had not really used the sketchy stroke project setting much before, so I can't remember how it worked before this 10.1.1 update. Again....this only happens after it is rendered.
any help appreciated
thanks again
Have you tried doing so on a new shape, from scratch? Do you have an example file you can share?
ThatsNotAllFolks
Yes I can create a file to share. Basically, if you choose sketchy for stroke under File > Project Settings and then render it via Command R, you get sketchy strokes in black no matter what color your artwork's strokes were.
sbtamu
Post by sbtamu »
ThatsNotAllFolks wrote:Yes I can create a file to share. Basically, if you choose sketchy for stroke under File > Project Settings and then render it via Command R, you get sketchy strokes in black no matter what color your artwork's strokes were.
Looks like this is a bug. In the mean time you can use the settings in the layers to get the effect you want.
Sorry for bad animation
ThatsNotAllFolks
Hello,
Do you have version 10.1.1 and if so is yours doing the same ....thankyou.
ThatsNotAllFolks
The sketchy stroke option in the style palette is not working at all. it won't even show it as black. **This is in addition to the Project Settings sketchy problem.
ThatsNotAllFolks
here is a video that I made further describing the issue.
https://vimeo.com/110267982
