Lens Flare Test
ianmage1
Lens Flare Test
Post by ianmage1 »
J.J. Abrams inspired... XP
I'm mostly satisfied with the lens flare (I'll have the flares' opacity fade gradually, next time), but not so much with the random jumpiness of the surface's perimeter; I probably placed the surface too close to the camera. That should be an easy fix.
Re: Lens Flare Test
I wouldn't rotate the rays - nowadays they show the orientation of the sensor cells, are only 4 rays, and get bigger and smaller.
Danimal
Re: Lens Flare Test
Post by Danimal »
It looks cool but is a bit on the overpowering side of things.
~Danimal
ianmage1
Re: Lens Flare Test
Post by ianmage1 »
@slowtiger Thanks for the tips. I made a few fixes.
@Danimal It's still on the "over-powering" side, but that's what I was going for in this particular sequence.
Danimal
Re: Lens Flare Test
Post by Danimal »
ianmage1 wrote:@Danimal It's still on the "over-powering" side, but that's what I was going for in this particular sequence.
That is a marked improvement, and is definitely still overpowering. JJ Abrams will probably come make out with you for using such a strong lens flare. :lol:
~Danimal
ianmage1
Re: Lens Flare Test
Post by ianmage1 »
Danimal wrote:JJ Abrams will probably come make out with you for using such a strong lens flare. :lol:
In that case, I should probably avoid using strong lens flares too much... :shock:
ddrake
Re: Lens Flare Test
Post by ddrake »
Oh, poor JJ. Lensflarephilia is quite a troubling affliction. But for those with concerns for the new Star Wars, the good news is you probably won't be able to see much of it.
-ddrake
sargumphigaus
Re: Lens Flare Test
Post by sargumphigaus »
J J ABRIMS HAHAHAW HAW HAW AHAW I THOT THIS WAS A TRALER FOR THE NEW STARWARS HAHAHAHAHA............sorry....i don't know what came over me.......
That celestial appeal really draws me in. That guys figure is stringy though. But all at once, I'm fairly certain that you're conscious of that as it was your choice in style to do so. keep it up.
Re: Lens Flare Test
Definitely better.
