Make particles in a particle layer change direction
- Equalrights4animals
I'm trying to create an effect of water flowing over a waterfall and I was thinking the best way to do that would be to have a particle layer and make the particles change direction and move down when they reach the waterfall. How would I do that or is there a better way to create the waterfall effect?
Re: Make particles in a particle layer change direction
Easiest way would be to set up separate particle layers for flowing, falling, and spraying water, and blend them together with blurry masks.
Thanks. What's a blurry mask?
Any layer you use as mask can be blurred.
I recently followed this tutorial to create a waterfall and it worked very well.
viewtopic.php?f=9&t=1956&p=10594&hilit= ... all#p10594
You can use a similar technique "control" the particles direction using follow path. I think I posted that in the forum some years ago, but I don't remember where.AmigaMan wrote:I recently followed this tutorial to create a waterfall and it worked very well.
Anyway, check this file:
https://dl.dropboxusercontent.com/u/544 ... ath_9.anme (right click, save as)
The "particle" layer is following the "path" layer. If you animate the path, the particles follow that animation.
