imported movie audio
I tried to import a movie file into a moho project and it's working fine except for the audio part, it's not sounding at all, is it supposed to work?
The movie file is a .mov, I'm using mac and running osx 10.4.2.
Mmmm... Maybe only a "lapsus", cause I remember have done this without any problem in the past, but now, when I go to "Select Soundtrack..." or "Impor --> Soundtrack..." and try to load a *.mov file for import his sound, I can't because in the "Select Sound File" Window only are mostrated "Audio Files" and I can't change it because is the only one option, am I made me mad? I dreamed this was possible?? In that case, who is more mad? the madman (jaja...) or the man which follows the madman?
Hehehe, cool that you share this with us. First i must laugh and then i must tell you that you can still import .mov as audio.Ramón López wrote:I dreamed this was possible?? In that case, who is more mad? the madman (jaja...) or the man which follows the madman?(...)
You are not mad.
Wait, do you grow and eat peyote???
Just enter "*.mov" in the "open" line and .mov's will be showed again. No panic
Thank you SUPER. blaaa!!!
I knew that this should be possible cause I did it in the past without any problem/complication cause I rememered that I could change Tipe: "Audio File" to "All Files" in Select Sound File window... Anyway it was only a "lapsus" (as I was afraid) and I'm happy now/again
*CIAO!*
