Anime 9.5
Whatever...
allamosa
Anime 9.5
Post by allamosa »
I have an animation a couple minutes long I have put together and when I put an audio file in the layers (wav) everything quits working.
Anyone know what I have screwed up?
Re: Anime 9.5
allamosa wrote:... everything quits working...
Can you be more specific? That doesn't really tell us anything to check.
Based on that description, this causes the moon to stop rotating or the US government to shut down. :)
allamosa
Re: Anime 9.5
Post by allamosa »
The animation has a lot of movement in it and its about two minutes long. Dog, truck, girl and a horse and wagon all moving at different times. As soon as I put a wav file of horse hooves nothing will move (animate) then.
Re: Anime 9.5
Try disabling "Allow frame skipping" in the Animation menu. Depending on how large the file is and your system specs, AS may not be able to do a real-time playback of both audio and animation in the workspace. Frame skipping will try to let you hear the audio, while no frame skipping will let you view all the animation (even if slowed down to accommodate performance).
