Spherical projection: grid for creating panoramic images
Finally I've updated to 9.5, mainly because of the cylindrical/spherical projection abilities. I want to draw backgrounds which work within this device, and I needed a grid to do that. Here it is, use it for your own purposes.
Re: Spherical projection: grid for creating panoramic images
Thanks, slow.
That's really helpful! Did you just draw that by eye, or ...
Well of course - I've got the perfect eye!
Nope. I found a very small example on the net, scaled it up and drew clean lines in PS over it.
:D -- I would have believed you if you said you had drawn it!! :wink: Thanks!
rocky53204
Post by rocky53204 »
Look forward to seeing one of your backgrounds!
OK, I'm nearly finished with the current project, so I allowed myself some play. Here's a first BG sketch over the grid just to see how it works. Load this into your AS 9.5, select "Script > Image > Spherical Panorama", select camera pan tool (7), play around. Hit cmd-J for nicer experience.
It works pretty fair in horizontal pans, but if you go to zenith or nadir you'll see the glitches. The room is a bit small for my taste, next time I'll do better. The lines of desk and floor are not 100% straight, but I think that's OK within this style.
The bookshelf in the back is something I did quite a while ago and re-used it already in different projects. Import the image into TVPaint and use the warp grid with some good resolution, I used 7 horizontal and 6 vertical points. Select columns of points first (marquee select) to shift horizontally in place. Then place the points so the connecting lines meet or follow the grid lines.
Maybe I'm a bit obsessed with the clear lines, a more painterly approach could be better. Looking forward what others do with this!
JCook
Post by JCook »
This is brilliant. Thanks for sharing this, slowtiger. What a great tool.
Jack
Wow, thanks!
I corrected the grid and now it's much better around zenith and nadir, with straighter lines. Not perfect, but good enough for hand drawn backgrounds. Here's the revised version:
Let's see what you do with it!
chucky
Post by chucky »
Thanks so much for sharing this Slowtiger.
I know I shall be be needing this one sooner than later. :D
Have a look at this test:
and notice the imprvements on the desk's bottom.
chucky
Post by chucky »
Pretty amazing ST, funny the shelves don't match the construction as masterfully as the less detailed parts.
That's because it's just a warped front view (showing the backs only) so far, without the covers being added. I already used this in other projects and it's quite convincing once the missing parts are drawn.
chucky
Post by chucky »
No worries , work in progress, I see. :D
