I recently installed Debut but I have very limited choices for output formats and resolution.
I know that resolution is a limitation of having the debut version of the software, Is there a workaround?
Also, how can I get more output formats? I have the option of FLASH and AVI but I would like the option to output in mpeg or MP4 or wmv. Is this possible.
How an I export at the highest quality in debut?
- hayasidist
Re: How an I export at the highest quality in debut?
Not even Pro can do more than SWF (with limitations), QuickTime (if you have QT installed - if you want this it's a free download from Apple; but 32 bit only - not an issue for Debut, but you can't use it on Pro 64 bit) and AVI (AVI on windows only).
You're stuck with 768*768 pixels on Debut. I can imagine a workaround based on using a compositing program and stitching together multiple renders, each of a different part of the image, but I wouldn't even think seriously about going there... try shopping around for Pro - there are often deals that bring the price down by quite a way (USD66 on Amazon.com right now - that price might not last of course!...) http://www.amazon.com/Smith-Micro-Softw ... udio+pro+9
That is good info, thanks.
Will my debut projects open in Pro with no problem?
- hayasidist
no problems at all using Pro to open files made in Debut. The big limitation is that you can't use an earlier version (e.g. AS6, 7 or 8 ) open a file made in a later version (e.g. AS9); so don't buy a very cheap edition of Pro7 to open Debut9 files - it won't work.
If you need to create a video file in a format that AS won't output, you'll need to use another program to do the conversion. Most of the serious users use a video editor to composite output from AS, and those editors have a much broader output capability. There's plenty of discussion on this forum about the "ideal" output format from AS for use in other video editing programs.
Right. after installing Quicktime, I now have the mp4 format as an option and it looks great. And I do do post editing in another program.
