head turn of dog
yadhu.nar
head turn of dog
Post by yadhu.nar »
how do i do head turn of dog
Re: head turn of dog
same as a man, but with a bigger nose :P
yadhu.nar
Post by yadhu.nar »
can recomed any tutorial but i want ful 360 head turn rotating camera tuorial the best u know
1. Do you really need a 360° turn?
2. AS is a 2D program, so you have to draw different views by hand.
3. Maybe a 3D program is better for you.
There are a lot of kind of dogs and a lot of drawing styles. If you share a picture of your character it will be easier to help you. Now, I agree (partially) with slowtiger. AS is a 2d software and you have to consider that. Most of the time a good anticipation works better for a head or body turn rather than having a very complex rig able to turn softly in every possible angle.
Anticipation & counteraction plus simple vertical axis flip:
yadhu.nar
Post by yadhu.nar »
hey here in anime studio library > characters> partner >victor paredes>goose avatar.there u will see that the layers play moving up and down here and there.i have planned to animate my dog in the same way help me and say how the move the layers in between of time line i had tried with 2 vector layer but it does not change its place in between of the time line
yadhu.nar wrote:hey here in anime studio library > characters> partner >victor paredes>goose avatar.there u will see that the layers play moving up and down here and there.i have planned to animate my dog in the same way help me and say how the move the layers in between of time line i had tried with 2 vector layer but it does not change its place in between of the time line
Hi, Víctor Paredes here.
That is an old file and, if I remember well, it uses blend morph and animated layer order. Now you could get the same result using smart bones. Currently, smart bones aren't able to control animated layer order, but they can translate layers, so you can use Depth sort (checking in the bone layer proprieties>Bone>Sort layers by depth). You can translate layers very little distances (like 0.01 or -0.01) and that way be able to animate the visual order of the layers.
All this is just if you want to control the movement using a bone lever. If you just want to animate it by hand, just move the points and adjust the layer order anytime you want.
yadhu.nar
Post by yadhu.nar »
thank u very much
yadhu.nar
Post by yadhu.nar »
slowtiger u said that i have to draw many views for 360 turn what should i do how plese tell me
