how do insert animated .gif/.png ?
marcelvaneijk
Post by marcelvaneijk »
i saw someone on a video importing a sprite in anime studio
and the sprite immediately played
when i try to to import a sprite all i see is the first frame
and it can't be played
the only way it works for me is when i import them one by one
and seperate them on the timeline
but that's probably not how it's supposed to be
Re: how do insert animated .gif/.png ?
AS doesn't recognize animated GIFs and will only show/use the first frame.
marcelvaneijk
so you're saying the video i have seen must be a hoax ?
i'll try to find the video
just to make sure
because if it does work like in the video it would save lots of time
sbtamu
Post by sbtamu »
They may have made the sequence in AS but used a photo editor ie Photoshop or GIMP to make the animated .gif like I did for the crying baby I use for my avatar on the forum.
Sorry for bad animation
neeters_guy
Post by neeters_guy »
A sprite can also be a sequence of images, which AS can import automatically via Scripts->Image->Import Image Sequence... The images will be put in a switch layer and keyframed on the timeline. The filenames need to be numbered sequentially for this work.
marcelvaneijk
neeters_guy wrote:A sprite can also be a sequence of images, which AS can import automatically via Scripts->Image->Import Image Sequence... The images will be put in a switch layer and keyframed on the timeline. The filenames need to be numbered sequentially for this work.
that sounds like what i've seen, thanx
