blur the background
skygaz3r
blur the background
Post by skygaz3r »
hello guys!
i was wondering if there is a possibility to blur a layer so it looks less "sharp"
and gets more this kind of "in the far background" look
sorry, my english isn't good ;(
rocky53204
Re: blur the background
Post by rocky53204 »
You might try enabling depth of field in project settings and then insuring z depth of your background layer is set back... let me know if this helps.
Use "blur" in layer properties. Tip: Render the result and re-import (and switch off the original BG layers), thus saving your computer processing power when rendering the animation.
arfa
Post by arfa »
If it is an AS composite render the scene and use P'shop to blur. You might also want to add a few other touches and appreciate the extra control in P'shop [or Gimp or..] - *then* re-import.
SpaceBoy64
Post by SpaceBoy64 »
Also, in Layer Settings, you could enter a number in the Blur Radius box. If you want it to change during the animation, you could check the allow animated layer effects box and set keyframes for the value in the Blur Radius box.
