hi
in the case of a serial for tv to be written by a friend and done perhaps by me
if any money from cnc (french tv money help for projects) i would like to build
my own templates as on the right of the software, to use it as in every episode
of the serial.
i personnaly own the 8.0 pro version of anime studio actually
thanx
stéphane
how to create own templates
- labonneanime
- labonneanime
Re: how to create own templates
hello
no answer i think i made you missunderstood
then i do not want to create my templates from
the template maker (nose more long etc) but import
my skills to keep it under my hand to animate cheaper
in a sort of way
is it possible ?
regards
stéphane
in a sort of way
is it possible ?
regards
stéphane
- hayasidist
do you mean make your own character parts (eyes, nose, body ...) and then use the Character Wizard to build your own characters? if so... yes - you can make your own templates for this... in the English version of the ASP8 manual it's page 394.
Voulez-vous dire que vous voulez faire vos propres éléments de caractères (yeux, nez, corps ...) et ensuite utiliser l'assistant caractère (CW) pour créer vos propres caractères? si c'est le cas ... oui - vous pouvez créer vos propres modèles pour ce faire ... dans la version anglaise du manuel ASP8 c'est à la page 394. Malheureusement je n'ai pas trouvé une version française du manuel.
I haven't worked with a professional production yet which really used the character wizard. Instead they created their characters and put them into separate project files, out of which they imported them into a scene file. Same was true for stock animation: walk cycles or other movements which appeared more than 3x in the series were done in a scene, then put into a separate project file and trimmed for easy re-use.
- labonneanime
hello new friends
yes i go to prepare by another scene the main character to have all movement and
lipsinc possibilities for
good idea to "respect" what i wants as dzign , impossible by character wizard
thanx a lot
stéphane
thanx a lot
stéphane
