Hi
Is it possible to adjust the global render style settings in AS8, as in, change the default cutout style edges thickness and color?
Thanks in advance
Alex
tweaking of Project Settings >Render Style >Layer >Cutout ?
Re: tweaking of Project Settings >Render Style >Layer >Cutou
I'm not aware of any fine tuning of these settings.
Did you test if different project dimensions yield different line thickness in the render?
I know this can be modified by scripting (I remember that was one of the cool things about this feature), but sadly I don't know anything about script writing, so maybe some scripter can help you.
Anyone here?
Anyone here?
Good question; haven't tried but also needing to change stroke color (to something other than the default paper-beige) won't just yet. I need to dig deeper.slowtiger wrote:Did you test if different project dimensions yield different line thickness in the render?
Scripting... ah yes, maybe. Thanks for the hint. Will try and share if solution found.selgin wrote:I know this can be modified by scripting (I remember that was one of the cool things about this feature), but sadly I don't know anything about script writing, so maybe some scripter can help you.
Anyone here?
