Bus-Tops
Steverino
Bus-Tops
Post by Steverino »
I've been making some short animation loops for Bus-Tops, a public art project that put red LED screens on the roofs of 30 bus shelters around London:
http://bus-tops.com/people/Steve_Tiffany/
Made in ASP: Tattooed Couple, Whee!, Coffee Time, Charm Bracelet Chain Gang, and The Crush.
If you submit some of your own work, they should be animated GIFs about 10 seconds long, 8 frames per second, 256 x 80 pixels. Work in grayscale -- black is black, of course, and white translates to the brightest red the screens can display.
Re: Bus-Tops
Very interesting initiative and truly cool works!
Some of your work shows a code to place the sprites around and morph the shapes. Which is the language used, the API and how to build and test it?
Steverino
Re: Bus-Tops
Post by Steverino »
Thanks! The coded ones were made in Processing. There's a tool and tutorial here:
http://www.stevetiffany.com/zips/BlendMorphTutorial.zip
Requires Processing, which is free here:
http://www.processing.org
It's easier to do blend morphs in ASP, but Processing is good if you need real-time blend morphs with interactivity.
sbtamu
Re: Bus-Tops
Post by sbtamu »
I made one today to check it out. It is pretty interesting web site.
http://bus-tops.com/work/4346/
Sorry for bad animation
rocky53204
Re: Bus-Tops
Post by rocky53204 »
I find the whole concept/process so compelling and unique! A gent in Iowa doing public art displayed in London... so very cool! Shall you do some Olympic shorts?
sbtamu
Re: Bus-Tops
Post by sbtamu »
I did this one last night. I am sure everyone can recognize the walk cycle. :D
http://bus-tops.com/work/4387/
rocky53204
Re: Bus-Tops
sbtamu, how very clever of you!
Steverino
Re: Bus-Tops
Post by Steverino »
Congratulations sbtamu, on getting Stickman's Olympic Balloons programmed. Texas joins Iowa on the cultural landscape of London! I agree with rocky53204 on how cool it is that Bus-Tops makes such a thing possible.
I just did an Olympic Rings one myself: http://bus-tops.com/work/4393/ It's supposed to have a wobble-3D effect. I think the effect is there, but it's on the subtle side. The real master of hand-drawn wobble 3D is Dain Fagerholm: http://www.boredpanda.com/hand-drawn-an ... gerholm/2/
sbtamu
Re: Bus-Tops
Post by sbtamu »
Thanks everyone. But is this good news or bad? Everyone in London are seeing my stickman's feet slide all over the place LOL.
rocky53204
Re: Bus-Tops
perhaps you are the master of the forward 'moon walk'
