http://www.contentparadise.com/productD ... x?id=17468
It now comes with a GUI in the form of an AS menu script (rt_aswrap_gui.lua), that lets you render the currently open document in much the same way you would using the File -> Export Animation command, only with extra options:
It also now lets you specify a custom ASPWrap python script to run when rendering the anme file. This makes many new things possible, such as the following:
- - Run ASPWrap multiple times on the same file, with variations, and combine the results. I plan to use this to write a motion-blur script and add custom blending modes and effects.
- - Interface with command-line encoders like FFmpeg to support extra video formats like WMV and H.264.
- - Store the render settings to use for a particular project or anme file.
- - Render a list of anme files read in from a file.
