Hi!
Here are the possible bugs and the steps I Followed.
SoundTrack Bug.
1. I used a 2:30 min soundtrack. In it I have 5 different voices.
2. I created 5 switch layers for the lip synch, with data that came from papagayo.
3. I started the playback and stop it to adjust some movements in the spot.
4. I started the playback again, but the play was going slower, and the soundtrack lower in tone.
5. After three of four stops, the play crawled and the voice was unrecognizable.
6. Once, I changed from one layer to another, and the speed got right again, but the trick didn't work too often.
7. Solution: I closed Moho and Open it again.
Text "don't know if" bug.
1. I created some text labels (Draw-Insert Text).
2. I scaled down the text since I needed small font.
3. All text was created at frame 0.
4. When starting the playback, the Text disapeared! I was able to see it only in Frame 0 (that is, in animation it didn't show) and all other shapes in that same layer were correctly shown.
5. I the selected one label, and did Cut.a
6. Positioned in Frame 1, I tried Paste. Moho Crashed.
Thanks!.
William.
Text Behavior / Soundtrack Playback
