How to Rotate a Shape
When I rotate points of a shape, it grows and recedes in size.
Is the only way to rotate it via rotate layer with trying to get the origin in the center of the shape?
Thanks
Thanks
you can select all points and then rotate 'em via 'rotate points' - the button next to 'scaling points' (in my Win-AS; Mac might be some different place but leads to the same result); the size will be exactly the same. When the points of a shape grow and reced in size you haven't either selected all points or your using 'scaling points' instead of rotating.FloridaJo wrote:Thanks.
So is there a best practice to get the 'origin' point in the middle of the shape, or just eye it?
But generally you can rely on this:
slowtiger wrote:The "rotation" of points is only useful in constructing a drawing, not for animation. Point animation always uses the shortest way from first to last position of every single point. If you need to rotate a whole shape, use layer rotation instead.
Actually I tried rotating all points.
It don't work.
Here's a screen cast of the issue.
http://www.youtube.com/watch?v=xCERHLd571E
Thanks
It don't work.
Thanks
Hey Florida jo, Another forum member modified the rotate points tool to include an option that will rotate a shape around its gravity center. Search for fazeks tools, if you can't find it let me know. I've got his tool set.
EDIT
here's a link to Fazeks thread where you can download his tool set.
viewtopic.php?t=3507
EDIT
Here I made a Tut on how to rotate an object
should someone in the future need to know.
Regards
http://youtu.be/1lB0MpFXSyI
Regards
[quote="FloridaJo"]Actually I tried rotating all points.
It don't work.
Thanks[/quote]
Saw it and in my opininion that is rotating objekts and not rotating points.
But I see you already solved your prob. Fine.
It don't work.
Thanks[/quote]
Rotation
Hi FloridaJo,
One way to do this is to set your object and orient it the center of the canvas by selecting all the points, select the translate points tool and setting the x and y values to zero. Then just use the rotate layers tool instead. You can also set the origin point by eyeballing it with the set origin tool but if you do this it's best to use the grid when creating a shape and setting the rotation point.
Also, just remember, even if you create a rotation of an object in the center of the stage, it doesn't mean it has to stay there. After creating the rotation move and scale it with the layer tools on frame zero to place it anywhere you want.
Practice random acts of kindness and senseless acts of beauty! Pause, consider, do! I dare you!
