When working out where to put points where is the origin to start from, is it the centre of the document (centre of origin) or top/bottom left/right
Also how do you workout the document size so any points are placed in the correct location.
Many Thanks
Centre of origin
Breinmeester
Yeah, some clarity on that is needed.
As far as i figured, 0,0 is at the exact centre of a layer. The anchor point has its own x and y location, so the point of origin is not depending on its location. The x and y axis are set as a ratio. Meaning that which ever is shorter is 1 unit big and the other is matched accordingly depending on your resolution in the project settings. So if the document is 400x400 x=1 wide and y=1 high. If it's 200x200 same thing. If it's 400x200 x=2 units wide and y=1 unit high.
That's all i know.
That's all i know.
- hayasidist
what Breinmeester says is right if you have the defaults (zoom=60 and camera at x=0,y=0, z=1.732; vector layer at z=0). but there's a dependence on zoom and (relative) camera z too.
here's the maths: the zoom is the angle of view (the angle from the camera point to the top and bottom of frame - assuming that's the shortest). so half the height of the frame is tan(half the zoom angle)*(cameraZ-vectorZ). in the default that's tan(30)*1.732. tan(30) is 1/(sqrt(3); 1.732 is sqrt(3); so half height = exactly 1. That's Y(max); and Y(min) is - that. multiply by aspect ratio for X(max) and X(min).
if you change the zoom or the relative z then the coords of render area top/bottom/left/right change.
I'll leave you to figure out what happens if you pan /tilt / track the camera.
