Hey all,
So here's my latest problem...
While there is no animation on the layer, the line width is constantly changing in the switch layer entitled "squished" .
Here's the file. I've removed everything but the face and eyebrows.
http://www.mediafire.com/file/7x6skarqq ... brows.anme
Can anyone see what I did to mess this up?
Thanks,
Jared
Line Width Problem
Yeah, I still get the problem.GCharb wrote:To be honest I see no such variations on my side.
Have You tried restarting your system and open the file again?
If you click on squished on frame 0, it has some thickness. around frame 432 is the first time I use it.... at that point the thickness has gone down visually to barely anything.
Not doing the same thing for you, huh?
- funksmaname
tick scale compensation on the squished layer - somehow you managed to untick it (it's off on happy eyebrows too)
In the properties for the layer.
In other news, i think you might be over complicating your life with all these switch layers - you can just flip the head instead of having a flipped copy to switch between - it means any changes in one have to be copied to the other etc.
In fact I wouldn't put all these eyebrows in switches either... personally I would use actions, or just manually edit them (bone them for up/down/rotation, and just edit the points when you need to) - I think trying to plan for every possible facial expression is probably a waste of time imho.
Thanks! I knew I had to have done something...funksmaname wrote:tick scale compensation on the squished layer - somehow you managed to untick it (it's off on happy eyebrows too)
Thank you for your suggestions too. I've never used actions, though I watched a tutorial on them months ago. I'll brush up and take a shot!
Best,
Jared
- funksmaname
