Strange effect on my tail
Maybe it's due to the shape effect of the tail, but I guess it's just a bug isn't it?
Greetings.
Not a bug, in some cases can occurs... my advice is that you could check that shapes that you belive creates the strange form, you can select the shapes one by one until you can see the scuared texture in the form, delete it and create again after that you check all points are perfectly joined and all is correct...
- Lost Marble
I can't say for sure without seeing the Moho file, but my guess is that when you created the fill shape, you included the middle line segments instead of just the outline of the overall shape. It's very important to include just the outside border curves of a shape - if you include any interior curve segments it can make the shape ambiguous. It may look right at first, but as you move it around, color may "spill" out of it as we see here.
