Change color of a complex shape.
Hello, kind people.
I am kind of a newbie with ASpro coming from Corel/Illustrator and trying to make something move. I read the help file, did the tutorials end to end. Easy.
Now I created my character in Corel and moved it to ASpro via Illustrator.
Rigged it, arranged it, but now i have to change its color. Nothing too complicated, my character is a single color thing made of several shapes, no outlines.
SO HOW DO I CHANGE THE COLOR of a compound shape, like say.. the letter "O" ? When i click it with the paint bucket i get the empty part in the middle filled as well. Then i have to use delete shape and create shape and I get some default color with an added outline or just an outline, and i want neither. When I undo something it comes up white.
What is going on?
Sorry for being a newb, but i'm raging over this already.
Added questions:
- How can I apply a style to something? I have a fill with no outline and i want to apply it to a bunch of objects. I can't get that one right no matter what i do.
- Can I make an object rotate around another object (in front and behind) without using the Z paramenter?
What is going on?
Added questions:
This solved manual mode, but i still can't use styles. I have one saved, i select a shape, it becomes semi-transparent, i select the style and.. nothing.
The object becomes deselected.
I can only apply a style by clicking an edge with the paint bucket. But this also fills any 'hole' in the object.
- funksmaname
tip one: don't ever touch the fill bucket
are you selecting the style in the TOP drop down? if so that's just for creating/editing styles... if you have 'advanced' ticked in the colour options, the two drop downs at the bottom are where you assign the style to a shape.
if you do that to everything then making changes to teh style itself using the top drop down will effect all shapes you assigned it to.
I encourage you to practice with the AS drawing tools too though, you will get much nicer/cleaner results than importing vectors... it IS good, just needs some practice
- funksmaname
I don't, it doesn't seem smart enough to know what to fill properly when you have lots of overlapping empty shapes... also, i've seen people create multiple fills so many times that result in a white pixel around the shape and then they don't know how to fix it - it's almost always down to the bucket and an over active clickyfinger
i highlight the shape and hit space or click the button on the interface to fill...
