Animation to Action?
Hi.
IS it be possible to write a script that can convert all the keyframes on a Bone Layers/Layers animation into an Action?
Or
Is there a another way to achieve this?
I have a lot of cyclic animations using the same bone structure I would like to save out as Actions for easy accessibility.
Cheers
D.K
Or
Cheers
D.K
My store on Renderosity:
Rudiger has a script for sale at Content Paradise that does just that. I've only done a few tests with it and it seems to work very well. here's the link to the script.
http://www.contentparadise.com/productD ... x?id=18107
Hi Guys.
Many thanks for your help.
Cheers
D.K
Cheers
D.K
I think GCharb is talking about PonySmasher's Load/Save Bone script that Mike Kelley later incorporated into his Swiss Army Tool.
Heyvern has a similar script, which he gives the link to in the same thread.
The main difference between these and my script, is my script works on every animation channel, not just bone animation and you don't need to name the bones, they just need to be in the same order.
Hi Rudiger.
Ahhh....I understand what you are saying. Verns load save animation script is;nt too bad. I use it all the time but the thought had'nt crossed my mind to load the animations into the Actions layer...duh
Rudiger.....I might give your script go
Thanks heaps
D.K
Thanks heaps
D.K
Hi Rudiger.
I purchased your rt_Import_animation_v1.1 script and it does'nt appear to work with AS 5.6.
I get this error message:
D.K
...o Pro\scripts\menu\Animations\rt_import_animation.lua:382: attempt to call method"loadDocument"(a nil value)
Yes, I'm afraid it only works with version 6.2 and above. I didn't realise you were still running 5.6. I'm sure you would be able to get a refund from Content Paradise.DK wrote:Hi Rudiger.
D.KCode: Select all
Hi Rudiger. No probs. I have all versions of AS being a Beta tester but I just prefer to use AS 5.6. I can use Verns script for 5.6 if I want to. I just wanted to see how yours worked.
I Just tried it in AS8 and it works well.
Cheers
D.K
Cheers
D.K
