ASP 7 & 8 vs 6
ASP 7 & 8 vs 6
Hey guys. Might want to upgrade from ASP v6 for my next project and wondering what the new features are in versions 7 & 8 that might make it worth it.
I've read about physics engine, the "new" curve methodology, the simple 3D shapes that can be drawn and extruded. . .what else? Fancy stuff to simple interface stuff (heard you can now select, move, delete, etc. multiple layers at the same time, etc.
Can't find the answers in a single comprehensive thread on here.
Is 8 Okay or is it buggy and I should maybe look at 7?
One of the biggest drawcards for me to AS 8 was the masking bug fix. It is also quite stable I find.
D.K
D.K
My store on Renderosity:
What was the masking bug? I used masking for extremely simple applications, like keeping this shape from going outside the boundaries of that shape. . .revealing something slowly from being invisible, etc. Never encountered any issues.
With the physics. . .just watched a tutorial on youtube, seems kinda neat. Can you do this kind of thing with it:
I had a character in my last short film flip a coffee table. I hand animated from trial and error everything that happened thereafter, from the rotation of the table/the speed at which it flipped, to the distance/timing and arc with which all the objects on the coffee table flew off and landed.
So can you, with the physics engine, do something like flipping the table, and the rest of the animation would take care of itself (objects would fly and land based on weight/gravity, etc.?
For a thorough explanation do a search but a small white/black line would appear where it was not supposed to when masking. Apparently it was due to AS antializing. Anyways it's been sorted in 8.
viewtopic.php?t=19216&highlight=masking+bug
Cheers
DK
Cheers
DK
You can. The trouble you may run into (I definitely would but I'm far from an expert using the physics engine) is getting the objects on the table to sit still until the flip. Items with collision turned on tend to constantly "dance" around.basshole wrote:So can you, with the physics engine, do something like flipping the table, and the rest of the animation would take care of itself (objects would fly and land based on weight/gravity, etc.?
Again, this was my experience, which was about two hours total of tinkering around. The way I worked around it was to use the Physics engine to create the keyframes I wanted, then turn the engine off and copy and paste the keyframes into a regular animation.
~Danimal
ponysmasher
Things I really like in version 8 that I think makes it worth it:
Shape select tool. Say you're on layer one and with the shape select tool you click on a shape on layer 8, that shape will immediately be selected instead of having to select layer 8 and then select the shape. You don't even have to have the tool selected, you can just hold ALT and right click on a shape at any time. Great workflow improvement!
Import a PSD file and get each layer as a seperate layer in AS. It will be imported in a bone layer but now you can also right click a bone layer and convert it to a switch layer.
Round caps on strokes. Instead of the ugly flat ends of strokes you can now have them rounded. Looks much better.
Curve profiles. This was introduced in 7 i think and I use it all the time for trees and grass and stuff. Some examples.
Stroke exposure. Animate how far along a line the stroke is visible. Some nice effects can be achieved. Also introduced in version 7
Follow path. A layer can be animated along a path. I think this was introduced in version 7.
Well, those are some of my favourite features.
ponysmasher
Not an expert on physics either but there is an option called "start asleep" which I think means that the object will remain stationary until something bumps it.Danimal wrote: You can. The trouble you may run into (I definitely would but I'm far from an expert using the physics engine) is getting the objects on the table to sit still until the flip. Items with collision turned on tend to constantly "dance" around.
ponysmasher
