Multiple Sound Files
wizaerd
Post by wizaerd »
Back in the day, MoHo and Anime Studio Pro only allowed for a single dialog file, which made timing and whatnot a real PITA... Does the latest version sof ASP (7 & 8, preferably 8) allow for importing multiple audio files?
I'd much rather record my dialog, with each line as an individual file, then import and keyframe or assemble them as needed as opposed to trying to time everything to 1 single dialog file, specifically if it's dialog amongst multiple characters...
jonbo
Post by jonbo »
Yes in 7&8. I've had up to 4 and just read a thread where the guys says he has over 40 audio files.
GCharb
Post by GCharb »
I tested v8 with 12 high quality 32 bits audio files recently, worked perfect!
wizaerd
Post by wizaerd »
Thanx guys, I appreciate the response.
jaakay
Post by jaakay »
Hi All,
Would you lipsync your audio files from within ASP or would you use Papagoya and import the data file. Which is better?
GCharb
Post by GCharb »
jaakay wrote:Hi All,
Both are good, but personally I prefer from with ASP.
wizaerd
Post by wizaerd »
Most tutoprials or videos that I see discussing lip synching only shows single audio files. Even the manual doesn;t cover multiples... Is there a video ot tutorila anywhere disucssing multiple audio files, specifically as it relates to lip synching?
My characters will have several different lines of dialog, split into separate files. How do I get them in, and placed at the right moment in the timleine?
