Bad lip sync
3deeguy
Bad lip sync
Post by 3deeguy »
I don't know how to correct what looked OK in papagayo. I will upload the file if necessary. Somewhere between papagayo and ASP7 and "export to avi.", I'm having problems.
Please take a look. http://www.youtube.com/watch?v=DP056TVtkUk
Cheers, Larry
SvenFoster
Post by SvenFoster »
If it looked good in Papagayo but not so much in the animation the only thing I can think is that you used different mouths?
Again, with little to go on thats the best I can do.
--Sven
What *if* the Hokey cokey *is* what its all about?
3deeguy
Post by 3deeguy »
I don't think I'm a good judge of how it really looked. I thought I got an acceptable sync in papagayo. The final result shows it's not as close as I thought. I studied the dat. file which doesn't look like a great match.
Cheers, Larry
jonbo
Post by jonbo »
Larry, check the frame rate in both apps. maybe papagayo is different from what your using in AS. if you can't find the problem, upload the file and i'll look at it :)
John
3deeguy
Post by 3deeguy »
I think I zipped all the necessary files. http://www.mediafire.com/file/2vyac91bg ... 0files.rar Thanks Jonbo.
Cheers, Larry
jonbo
Post by jonbo »
Larry, see if this dat. file is closer to what you want, if so it is a matter of tweaking more in papagayo.
http://www.mediafire.com/?3903ybyy60wtws7
3deeguy
Post by 3deeguy »
jonbo, it is better. I will compare the two files in papagayo. Thank you.
Cheers, Larry
