Here is just a small snippet of what I experimented with today.
I took part of an animation I had done in Moho (illustrated in Adobe Illustrator - my favorite drawing program) and then I exported the animation as .psd layers.
There were 4 main upper layers.
In Photoshop:
-Blurred to Mountain layer better to my liking using one of the Photoshop blur filters.
-The sand layer, I used the blur tool and blurred the back (top) edge so it was not so sharp looking and gave it a bit of depth to it (it needs more work, but I was just experimenting).
-The sky layer I wanted a better graduated sky, so I added a new layer in Photoshop and created a gradient sky of dark blue, pink and yellow. Then I took the blue sky layer with clouds animated in Moho and put this above blue, pink,yellow sky layer and gave it a transparency of 50%.
-I then added the yellow glowing yellow ball into each frame of the animation.
-Then using the Photoshop filter "Lighting Effects" I created the glow/light on the boy´s face and body.
The difference in the before and after is quite dramatic.
(click for larger view)
Here is a very short video clip showing just 18 frames of the animation Before and After.
Toontoonz Before and After.mov 0.97Mb.
You will be amazed at what you can now do with Moho combined with Photoshop (and Adobe After Effects and....).
It puts Moho up a whole level or two as far as what one can do with it.
One is only limited by their imagination!
