Poser 8 and Anime Studio Pro 7 Integration
Is it possible to lip sync an imported poser character inside AS7?
there is no automatic lip-sync for imported figures in AS itself, but you can use the talk-designer in poser to do the mouth animations first, then save and import the scene into AS . or you could create actions in AS for each of the phonemes, and do the syncing manually. it would be a slow way to do it but could be done. you can run your audio file through PAPAGAYO first to get the phonemes and timing placements so you could use them as a guide.
