Is AS7 missing some buttons?
jhbmw007
Post by jhbmw007 »
Is it just me or are the raise/lower shape buttons missing? The only way to access these is from the menu now? Also used to be able to press the "p" key to "peak" a point when selected- this does not appear to work anymore.
sbtamu
Post by sbtamu »
The shortcut to raise and lower shapes is the up and down arrows and if you hold shift you raise the shape to the lowers or highest with the arrow key.
The Peek/smooth short cut is c.
Sorry for bad animation
There is a tendency to reduce buttons in newer versions. But don't worry, all the functions are there.
- To change shape order, use the select shape tool, select your shape and use Up and Down on the keyboard.
- P and M now are Control+P and Control+M
sbtamu
Post by sbtamu »
Ah I did not know I could skip a step by hitting ctrl P/M.
