Export to Photoshop --- in layers! (Layers is the key, the magic word!)
Now this opens up a whole new world of fun possibilities.
(Tip: Think Photoshop filters, Photoshop´s great masking abilities, actions applied to layers...whoo-hoo!!!
Perhaps you should try to subscribe to the usergroup mailing list, then you get the announcements and relevant links from L.M. sent by e-mail once your membership is approved.DaleG wrote:thanks! I searched the forum for 5.2 and couldnt find it.. completely missed the category of announcements...
From Moho announcement:DaleG wrote:now if I can figure out how to import a layered photoshop file... (I thought I had to convert to png file with no layers..)
However, I assume one can export separate layers as PNG files from Photoshop and import those as separate layers into Moho. I also assume Photoshop has the necessary tools to automate this layer-by-layer export process. So this might be a workaround.Toontoonz wrote:It doesn´t say you can IMPORT layered PSD image files into Moho, it says you can EXPORT images from Moho as layered PSD (Photoshop) image files.
I think of this more like PNG or a movie with an alpha channel, which will leave out the background color also. The assumption is that if you're exporting PSD, then you probably have some compositing/post-processing operation in mind and you're either going to layer the animation on top of some other background or maybe experiment with different background choices.Rasheed wrote:Also, the background color (from the Project Settings) is always transparant, unlike Render or Export Movie.
Both of these open fine for me in Photoshop. Is anyone having problems with these sample files? If so, which version of Photoshop are you using?Rasheed wrote:Please, see if you can read the files I've prepared in this zip archive:
2) objects0001.psd (exported from Moho)
3) objects0001-mod.psd (imported/exported through Gimp)
