Without ending up with a blurry mess. I could change the size in Photoshop beforehand, but to do that for a lot of scenes is a mission. It'd be great if I could find a way to avoid this:
It'd be great to be able to render a 110 pixel sized image much larger without anti-aliasing, similar to how Photoshop can size up or down with a 'nearest neighbor' interpolation that doesn't smooth pixels, instead of the 'bilinear' that I suspect AS uses as default.
Wonder if this is an easy correction or a script or something could do this?
Strangely, the image looks absolutely perfect in the AS work view. Its just when rendering things go a bit weird.
Thanks,
Mike
