Animate imported images
WorkingMan
Is it even possible? I want to import an image (like my own drawing) and add vectors and bones to it. I scoured the interweb looking for an answer and have turned up zip.
Thanks
Thanks
Have you read the AS documentation and done the tutorials? Image layer animation is covered.
You have two choices:
1. Animate image layers with bones or layer transformations
2. Use the image as a reference to trace and recreate in AS with vectors
If you are using some other drawing application like Adobe Illustrator you could import AI or EPS as vectors in AS.
Animating images uses pretty much the same process as animating vectors. The main difference is that image bone warping is not as precise as using vector layers. You still need to understand bone layers and bone binding for either technique.
WorkingMan
I think you should take a look on the tutorial before asking here. Sorry, but what you are saying is very basic and well covered on the tutorial.WorkingMan wrote:I'll import a .png image, and it won't let me add vectors or bones to the layer.
WorkingMan
I'm not even sure what tutorial I'm supposed to be doing here... I did the 4.1 with the hula girl and that didn't really help me out. It gave me an image that had already been vectored and boned (lol) and all I had to do was bind the bones together. It didn't really help me with figuring out how to vector my own image. I'll import an image and select the layer but it wont allow me to add bones or vectors. I'm looking at the Images section on page 51 of the manual, and I'm not seeing anything. Am I looking at the right thing or what?
Check this old Moho introduction. Some info is anachronistic, but most will be fine for you.WorkingMan wrote:I'm not even sure what tutorial I'm supposed to be doing here... I did the 4.1 with the hula girl and that didn't really help me out. It gave me an image that had already been vectored and boned (lol) and all I had to do was bind the bones together. It didn't really help me with figuring out how to vector my own image. I'll import an image and select the layer but it wont allow me to add bones or vectors. I'm looking at the Images section on page 51 of the manual, and I'm not seeing anything. Am I looking at the right thing or what?
http://www.lostmarble.com/moho/manual/i ... gmoho.html
AS is based on "layer types". An image layer can only contain an image. A vector layer can only contain vectors. A bone layer only has bones but is a "group type" layer that can contain other layers like images and vectors inside it. Those layers are controlled by the bones drawn on the bone layer itself. You can't "draw bones and vectors" on an image layer.WorkingMan wrote:I'm not even sure what tutorial I'm supposed to be doing here... I did the 4.1 with the hula girl and that didn't really help me out. It gave me an image that had already been vectored and boned (lol) and all I had to do was bind the bones together. It didn't really help me with figuring out how to vector my own image. I'll import an image and select the layer but it wont allow me to add bones or vectors. I'm looking at the Images section on page 51 of the manual, and I'm not seeing anything. Am I looking at the right thing or what?
This is all covered in the documentation and is the fundemental nature of AS, each layer type contains a specific type of content, image, vector, movie etc. Group layers like bones contain other layers.
WorkingMan
I can't add bones
Why won't it let me add bones to my character, I created it in moho and it is a bone layer, but it won't let me add bones.
My heart is pure as a flushed toilet
Adding bones
Thanks, that was the problem, it was at 1 not zero
