Thank you, njoo2as. I only rigged and animated the characters of all shorts. Other four guys made the final composition of the four shorts using After Effects. The water shine was made by a fusion of real footage with the original drawings, it implies several effects I couldn't detail because I'm an amateur on AE.njoo2as wrote:Like gleeful said, its INSPIRING! Did you make the the backgrounds as well or just the characters? Were the lighting effects done in AS or another program?
Four Mapuche shorts
Re: WOW
Re: WOW
Ahh ok...I figured it was AE. Thanks! I'll look up some AE + AS tutorials online.selgin wrote:Thank you, njoo2as. I only rigged and animated the characters of all shorts. Other four guys made the final composition of the four shorts using After Effects. The water shine was made by a fusion of real footage with the original drawings, it implies several effects I couldn't detail because I'm an amateur on AE.njoo2as wrote:Like gleeful said, its INSPIRING! Did you make the the backgrounds as well or just the characters? Were the lighting effects done in AS or another program?
Re: WOW
I don't think there be much "AE+AS tutorials". The principle is very basic, you export the animation from AS with alpha channel. Then you import that video on AE and do your magic. I mean, learn how to use both softwares and you will understand how to use together.njoo2as wrote:Ahh ok...I figured it was AE. Thanks! I'll look up some AE + AS tutorials online.
Anyway, to save your money and your brain, you can make a lot using just AS, technically there is no urgent need to use another software, you can get wonderful results in AS.
