Content Library 'flaky'
Peteroid
Post by Peteroid »
The Content Library seems flaky. Many times when I try to use the Content Library AS7PRO locks up (it says it is not responding).
It does it most when I try to search.
It doesn't do this consistently. I can search for 'mouth', and it works. Then later I'll search for 'mouth' and it locks up. Just now, it locked up when searching for 'mouth'.. then I closed AS7PRO and searched again and it locked up again... now it locked up every time until I re-booted my system!
THEN after rebooting my system, it worked again.
I think a lot of my problems stem from my OS being 64-bit Win 7...
[==Peter==]
chucky
Post by chucky »
I often get a WSOD when opening the library, even with no project open.
Also win 7x64
cymbiotica
Content Library issues as well
Post by cymbiotica »
I am on Mac OS X 10.6.5 with the following specs and ever since my first opening AS7Pro, I have not been able to view the content library.
This is troublesome to someone like myself who has no drawing skills and is learning this as I go. Hopefully this can be fixed for us sometime.
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Mozbo
Post by Mozbo »
Have you upgraded to 7.1?
I know they resolved some lock-up problems, but I'm not sure which.
~M
Change is inevitable, growth is optional.
Life is short, enjoy the adventure!
Patmals
Re: Content Library 'flaky'
Post by Patmals »
Peteroid wrote:The Content Library seems flaky. Many times when I try to use the Content Library AS7PRO locks up (it says it is not responding).
Ihad this problem when i decided o ry the latest IE beta..ASP wouldnt completely start! after reverting back to IE8 it worked fine again.
