AS7 crashes when I want to use the visibility script
Diana Kennedy
Post by Diana Kennedy »
Hm, I have a problem. AS7 crashes when I want to apply the visibility script, especially in Big files. Is there a way to bypass the script or to fix that bug? In AS6 it was possible to set visibility in every frame hence making fade away a layer "by hand" but this seems not to work in AS7.
You could try using a switch layer instead...?
Diana Kennedy
Yes, but it is very uncomfortable in this case - but I found out how to do now: I create the sequence in another file which doesn't crash and then import it as "Anime Studio Object".
