Open Source video editing software
The pro video editing software Lightworks is soon to become Open Source.
Those that register will, apparently, be first to be offered it free.
Go here...
http://www.editshare.com/index.php?opti ... Itemid=203
and click on 'Download' on the left and fill in the form if you are interested.
Go here...
Haha, isn't that always the way. I looked high and low for an open-source editing solution for many years but had no luck. I eventually gave up and bought Adobe Production Suite Premium off of Amazon for $1700 a few months ago!
Anyway, this is great news for both the open-source community as well as movie makers everywhere!
Thanks for the tip, AmigaMan!
Exactly same problem here.uddhava wrote:I downloaded and installed the software, but when I start it up it begins to initialize and then closes. If any one has had success or problems please post. Looks like a great software. Thanks.
Ok, I uninstalled Matrox codecs and now the software opens. The problem now is that seems to be no one video format is accepted.
I left the codecs installed, but to start the application I went to the program files Lightworks folder and clicked on the ntcardvt file which is listed as an application and started it from there.(Lucky guess) Now it starts from the regular shortcut and will open different video files, but not all. However, it crashes a lot. I will look at it more later.
udd
udd
Wow, that worked, thank you!uddhava wrote:I left the codecs installed, but to start the application I went to the program files Lightworks folder and clicked on the ntcardvt file which is listed as an application and started it from there.(Lucky guess) Now it starts from the regular shortcut and will open different video files, but not all. However, it crashes a lot. I will look at it more later.
Now all is about understanding it... I'm familiar with premiere and final cut, but this seems to be very different. Good, I like paradigm changing.
