Sorry if I appear like the bad guy again, but I cannot help it
In a previous post I mentioned several tv shows and movies made with Flash, like Atomic Betty, Quads, Chaotic(Who I believe is made with TB now) and many more.
Flash has a huge user base, hense it's many use in the field of tv series production.
Toonboom has a studio oriented set of tool, and true AfterFX has better composition, but Toonboom comp is adequate for the most part and it is already integrated in Toonboom pipeline.
I am sure ASP is used in many studios, but never heard of any making large scale tv series with it.
And yes I do believe that asp will ammount to an incredible studio tool, it is impressive as it is, but at the moment, as far as I know, except for a few studios like you guys, not so many uses ASP in tv series, and even then, those are small shorts in limited quantities.
It is really about the artist not the tools, but specialized tools will always have the bigger parts in productions, at least, from my experience.
I work mostly in 3D. At work, we use 3D tools that sells in the many K, even though there are free 3D package out there, that is because these expensive tools can chunk out the job much faster, same goes for 2D, again, from my experience.
BTW, the reason I am writing this, is because I use ASP, now, if I thought other tools we're best, i'd use them instead!
I think it is important not to idealize a piece of software and be truthful about it. ASP rocks, but it has shortcomings that needs workarounds, this said, it really does rock!
One last thing, what could make ASP a better contender, in my opinion, would be a better workflow for point animation, a bit tedious at the moment, just my two cents here, plz do not throw rotten banana's my way!
G
