Anime Studio 7 is now available
Tagirijus,
I think you're in luck! Have a look at http://anime.smithmicro.com/index_pro.php where you'll read...
Then shed a tear for me - I went to ASP 6 Pro in April!
FREE UPGRADE INFO: If you purchased Anime Studio 6.0 from a Smith Micro authorized reseller AFTER 5/9/2010, you qualify to receive a free upgrade. Fax your dated purchase receipt, your email address and your serial number to our customer service group at 831-761-6206.
- toulouse2k
A real stupid newbie(maybe even n00b) question
I've played with AS_7 Pro a bit...like it....but how do you access the Simulated Physics? Is it in the bones? LOST and waiting for definitive Tutorials.
- Víctor Paredes
Re: A real stupid newbie(maybe even n00b) question
you have to create a group and put your layers inside. Open the group proprieties and activate Physics. Then, you can setup each layer proprieties. Remember to create a ground.toulouse2k wrote:I've played with AS_7 Pro a bit...like it....but how do you access the Simulated Physics? Is it in the bones? LOST and waiting for definitive Tutorials.
- toulouse2k
Glad you asked. And sorry for being a bit off topic here.rogermate wrote: Hi Rylleman,
what animation software do you use on Linux?
My main tools is Anime Studio Pro(v6) and Synfig Studio. then I use some other tools to different degrees;Pap and Pencil. Also relies heavily on Gimp, Ffmpeg, Avidemux, Kdenlive among others.
TVPaint has released a linux beta which is very great. I do mostly cut-out animation so I have not been using TVP much as it's targeted towards drawn animation.
wellwisher
Re: Anime Studio 7 ..Help
Can we make Our own Content Library. I don't need the default one. And it is not possible to copy all the project folders to C drive. Any solution?
I only know a little... So teach me
I'm not exactly sure, what your problem is, but maybe this can help you:
viewtopic.php?t=16654
Good luck; helped me.
The content library doesn't work at all if you firewall ASP to stop it talking to Content Paradise.wellwisher wrote:Can we make Our own Content Library. I don't need the default one. And it is not possible to copy all the project folders to C drive. Any solution?
aka
FAULT Detected!
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://127.0.0.1:11730/apps/lms/api.py"] messageId="E07E6171-D5E9-D6BF-8E62-98B2A944D609" type="fault" bubbles=false cancelable=true eventPhase=2] --- Fault Request Info:
op=appConfig
