Moho 12.4 Update
Re: Moho 12.4 Update
shift wrote:I am having this same issue. I have Moho 12.4 and onion skin is enabled but there is no shadowed image.
You may need to uncheck "Draw behind".
chucky
Post by chucky »
is draw behind disabled or not?
Onion skin should work...I use it from time to time at work.
Can you post a screen cap? Is it possible that it's actually there but you don't have the necessary options set for it to be visible? For example, I usually have Draw Behind disabled so I can see the images.
You probably did this but, just in case, make sure sure you have at least one onion skin frame marked. Onion skin is not visible if no before/after frames have been marked.
starfish30
Post by starfish30 »
Just updated to 12.4 and Moho crashes immediately. I'm on OSX 10.9.5.
starfish30 wrote:Just updated to 12.4 and Moho crashes immediately. I'm on OSX 10.9.5.
* The Moho 12.3 installer will be provided for users of 10.9. Moho 12.4 installer provided for 10.10 and higher.
https://my.smithmicro.com/anime-studio- ... ments.html
starfish30
Thanks!
