*NEW* Switch Icons (updated 12/13/21)
kungfudork
Re: *NEW* Switch Icons
Thanks Wes! You nailed it! I've been wanting this since v10...hahaha. Can't wait to put it to use!
rocky53204
Holy crap! That is phenomenal! Blown away!
Thanks, guys, and especially kungfudork for rekindling the fire under my ass on this tool.
Re: *NEW* Switch Icons (updated 8/1/21)
[UPDATE 8/1/21]Workspace scrub time speed: You can now scrub through the timeline by clicking & dragging in the workspace, so you don't have to move your cursor so far from the switch icons. This setting lets you adjust the relative speed between mouse dragging and timeline scrubbing.
EDIT: Updated again to allow more flexible workspace scrubbing settings.
Re: *NEW* Switch Icons (updated 8/15/21)
Updated with a small UI improvement. Now there's an APPLY button for the settings, or you can still hit ENTER twice.
Re: *NEW* Switch Icons (updated 8/16/21)
Updated to speed up thumbnail rendering.
- gilcartunista
Hi Wes! Works WONDERFULLY on v11!!!
Eternally grateful for your generosity! As soon as I can repay you with a donation!
Thanks for the updates.synthsin75 wrote: ↑Sun Aug 15, 2021 4:36 pm Updated with a small UI improvement. Now there's an APPLY button for the settings, or you can still hit ENTER twice.
On the "Apply" button. I have to click that twice. Is that intended?
After using one of the settings drop downs, it doesn't seem to register the first click. Even just clicking an empty space in the settings counts as the first click.
I didn't figure out why.
Seems to be an issue with Moho, as the bone constraint menu behaves the same. If you use a drop down, it doesn't register the next click.
- gilcartunista
Hi Wes! In v11 this problem does not occur.SimplSam wrote: ↑Mon Aug 16, 2021 11:30 amThanks for the updates.synthsin75 wrote: ↑Sun Aug 15, 2021 4:36 pm Updated with a small UI improvement. Now there's an APPLY button for the settings, or you can still hit ENTER twice.
- gilcartunista
Yeah, I thought it was a newer problem in Moho. Thanks for verifying that.
Awesome script!
I'm amazed at all the nifty options, for example, the option to arrange the thumbnails vertically.
It is my understanding that when scrubbing in the workspace, the first click doesn't do anything because of a Moho quirk, and then the second click activates the scrubbing capability. I have a question: Is it possible to make the first click do something, like change the cursor to a hand? Or make a circle flash around the cursor for a fraction of a second? Or have the speakers emit a beep? I don't mind clicking multiple times when each click has a consequence, but a click that does nothing makes me think my mouse battery died.
I can't program in Lua, so I have no idea if this question is absurd.
Regardless of the click that doesn't do anything, it is an excellent script that I will use a lot.
Scrubbing in the workspace is a great feature. I like how you can change the scrubbing speed to suit your personal preference. I like the slowest setting, personally.synthsin75 wrote: ↑Sun Aug 01, 2021 7:03 am [UPDATE 8/1/21]Workspace scrub time speed: You can now scrub through the timeline by clicking & dragging in the workspace...
I'm not seeing that here. After clicking an icon, to change a switch, the next click&drag immediately scrubs the timeline (with a little pause entering or exiting frame zero). The only dead click I know of is in the settings menu, after using a drop down and trying to immediately hit APPLY.Hoptoad wrote: ↑Thu Aug 19, 2021 8:14 am It is my understanding that when scrubbing in the workspace, the first click doesn't do anything because of a Moho quirk, and then the second click activates the scrubbing capability. I have a question: Is it possible to make the first click do something, like change the cursor to a hand? Or make a circle flash around the cursor for a fraction of a second? Or have the speakers emit a beep? I don't mind clicking multiple times when each click has a consequence, but a click that does nothing makes me think my mouse battery died.
If it's behaving differently for you, which version of Moho? Maybe get a screen capture of the behavior?
