Moho 12.2 still crashes constantly
Re: Moho 12.2 still crashes constantly
Glad that helped!
NealF2 wrote: ↑Fri Dec 19, 2025 5:37 am ...I'll learn more about the Library so I can use that to reuse characters instead of importing from another file.
Moho's import feature should be fine; it doesn't appear to be doing anything wrong in this situation. If there's something wrong with the 'non-Moho' content, it needs to be fixed in another program (e.g., a compatible image, sound, or video editor). Sometimes, simply re-exporting or re-saving from the other program does the trick.
Using Moho's Library should be fine too, and if you're mainly using only Moho content on a small network, it can be a good system. I rarely use the feature myself, but mostly because I need to share data across multiple software packages and computers, which, in my opinion, exceeds the Library's capabilities.
Re: Importing old Moho files into a newer version, yes, this can have unexpected results because of the different data structures. The safest way to do this is to import or open the scene in the version of Moho you're using, test the rig, and make any necessary corrections. After the rig is working correctly, then it can be saved for that version of Moho, and imported into other projects of that same version.
The things to watch out for vary by Moho versions, rig structure, or workflow. For example, going backward from Moho 14 to an earlier version of Moho can add Bone Physics to all bones. In the past, I know moving files in or out of Moho 13.0 to other versions can cause all kinds of problems with Smart Bone Actions, so I avoid using 13.0 completely. Moho 13.5 (the Lost Marble version), on the other hand, is generally safe for import/export. Regardless, the rigs are always fixable if they show problems. After fixing them for a particular version of Moho, they should be fine for that version.
For example, the Mame-chan character, who appears in some of our tutorials, was originally created in Moho 13.0, then moved to Moho 12.5, and then moved to Moho 13.5, and finally brought into Moho 14.x when we started the tutorial series last year. I've had to make small adjustments and fixes in the rig for each Moho version, and it's since been fine to use in Moho 14.x all year long.
NealF2
Post by NealF2 »
Got it working!!
I suspected it had something to do with an old character that I imported.
So I created a new file for just re-creating that character.
I did keep the head of the old one since I was hoping not to have to re do all the mouths.
The shirt is a raster file. Thought that was part of the problem but turns out it's fine.
I recreated the rest of the body from scratch.
Then I created a head turn, testing all the way through. Worked fine in that file. Then I saved it to the Library and opened the new character in the main file that it needed to be in.
It worked! That library brought the head turn action in, too. Wasn't sure it would do that.
So now... off to work.
Thanks again, Greenlaw, for all the help.
M1 Mac Mini.
Moho Pro 14
Cool! Glad you got it working! :D
