MarkBorok wrote:I'm sure it's not impossible to make gradients that move with the object. If Flash can do it, Moho certainly should be able to (and Moho doesn't have to calculate the gradient on the fly, only at render time).
I use to think that, too, but now that I´ve come to think of Moho not as a vector program like Flash, but rather a spline-based program like Hash Animation Master. What one thinks can work in a vector-based program such as Flash or Illustrator does not hold for the spline-based Moho.
To me Moho is making 2-D "models", rather than Flash or Illustrator-like vector drawings.
All the effects in the Style window (shading, glow, splotchy, gradient, etc ) that one can apply to a Moho shape seem to be oriented to the Moho main window, not the shape. (Whereas in a vector illustration program the gradient is aligned in relationship to the vector shape.) All angles that one can set for these style effects in Moho are in relationship to the main window, not the shape or any other layer or object. (When one puts in 90 degrees for the shade effect ,this is 90 degrees in relation to the main X and Y axis of the main view window, not any shape or layer.)
It would be nice if one had the option to orient any gradients or other effects to the shape; however, it is probably not something that we will see in the near future or ever. Hence, as you say, LM pushes the use of image maps. (Even all the brushes in Moho are image bitmaps - jpeg or png files- crammed together, not vector-type brushes.)
