My Nudge Keys Toolset... Finally!!!!
lucasfranca
Re: My Nudge Keys Toolset... Finally!!!!
Post by lucasfranca »
Maestral wrote: ↑Tue May 23, 2023 3:59 am These icons should be placed/found in the Script Resources folder.
I've updated the previous installation so I have FO_icons folder there, in which you'll find these icons.
All of these, in my case, are in Custom folder.
Ok, I found the predecessor and renamed the icons.
If anyone else needs: https://1drv.ms/u/s!Ah7UWMCgRFbGh-076uf ... A?e=RiqgPh
https://youtube.com/animai2D
Lukas
Post by Lukas »
lucasfranca wrote: ↑Tue May 23, 2023 3:12 amSome icons don't show up for me.
I re-uploaded them as part of FO_Utilities, could you try downloading the tool again and see if they show up for you?
lucasfranca
Lukas wrote: ↑Tue May 23, 2023 4:56 am
I found the ones from the old version and already renamed them. Did anything else change? Thanks!
Lukas
Post by Lukas »
lucasfranca wrote: ↑Tue May 23, 2023 5:16 amDid anything else change? Thanks!
The consolidated timeline button works completely different now. Instead of creating a new layer with keys, it adds markers. And if you scrub the timeline with the tool active, and it reaches one of those markers, it automatically filters the layer panel to show the layers that have keys on them on that particular frame. And the buttons in the toolbar for layer filtering and channel filtering are now using the same system as a couple of my other tools such as LK_TweenMachine, LK_KeyTool, LK_InsertActions. Which I'll upload some other time.
lucasfranca
Lukas wrote: ↑Tue May 23, 2023 6:03 am
Esse botão não funcionou aqui, olhe: Image
Lukas
Post by Lukas »
lucasfranca wrote: ↑Tue May 23, 2023 12:32 pmImage
That's happening because you've used layer offset. The FO_Channels utility doesn't like that, sorry. We *never* use the sequencer, because it shifts frame 0 too and causes problems. I'll try to fix it at some point.
Lukas
Post by Lukas »
If you download the latest version from MohoScripts.com the 'Global Nudge Keys' buttons have been redesigned with a globe instead of a folder. It was causing some confusion because the folder seemed to represent a group layer. If you want to nudge a single group layer, use the button without the globe. And make sure you have the child layers button toggled ON to include child layers.
1x
2x
lucasfranca
Lukas wrote: ↑Fri May 26, 2023 3:02 am If you download the latest version from MohoScripts.com the 'Global Nudge Keys' buttons have been redesigned with a globe instead of a folder. It was causing some confusion because the folder seemed to represent a group layer. If you want to nudge a single group layer, use the button without the globe. And make sure you have the child layers button toggled ON to include child layers.
1x
2x
Sorry to intrude, but if you didn't explain it, it would take me a while to understand. Isn't using an image like that better? https://www.flaticon.com/free-icon/worl ... id=1102133
I'd have to agree. Even at 2x they don't readily read like globes to me.
Lukas
Post by Lukas »
Yeah, it's not the best, you're right. I might give it another shot later... At least, for now it's definitely not a group layer 🥴
martin_mrt
Post by martin_mrt »
Hello,
Im using the latest version of nudge keys (https://mohoscripts.com/script/LK_NudgeKeys) and ran into a problem:
I want to nudge only my selection, not all points right or left of the timeindicator. I understood that I have to change the Cannels option on the right hand side (the right one should be activated). whenever i try to press that button though it immediateley jumps back to the initial state (left button).
Did I miss anything? Could there be anything wrong?
Glad for any tips, hints or guidance. Im used to nudge with shortcut from ae. Would come in really handy with a task im just about to do.
I don't know if this helps, but have you tried the new Push Frames feature in Moho 14.4? It doesn't work with key selections, but it moves all currently visible keys on the right side of the Playhead to the right or left, and you can set frame intervals for the nudging. This feature is in the timeline controls.
martin_mrt
Thank you! I did try it now. Very useful for some situations.
What i am missing/searching though is the ability to push a selection a bit right or left. I do this often in later phases of the animation when it is time to refine the movement.
I get the feeling that "Push Frames" is always about moving the entirety of frames in MOHO.
