My Nudge Keys Toolset... Finally!!!!
Onionskin
Re: My Nudge Keys Toolset... Finally!!!!
Post by Onionskin »
Lukas wrote:
Onionskin wrote:
bubai wrote:Is it possible to share the corrected script for animestudio 10.1. PLEASE!!!
Beware, it's only updated so it works again. But the new 10.1 channels are not supported. (Everything will get nudged, but the new channels will stay behind)
Yes, true. I should be more specific, thanks Lukas.
On the link above is just updated "rt_key_tool_v1.2" script to work in the ASP 10.1.
No new channels are supported, like some animated layer effects, Threshold, Layer color...
rrahh
Post by rrahh »
The script does not work in AS11, at least i can't get it to work.
Is there something i can do to change this?
GaryC
Post by GaryC »
I was looking over this and I found a simple fix to make the menu appear when you click the tool.
I added this in right before the DrawMe function:
function RT_KeyTool:OnMouseDown(moho, mouseEvent)
	mouseEvent.view:DrawMe()
end
As far as I can tell, it works perfectly fine with just that added. If it has adverse effects for anyone, let me know so I can look into it!
rrahh
Post by rrahh »
Yeah! It works!
Thanks a lot GaryC!
GaryC
Post by GaryC »
No problem, glad it worked. Though it turns out this was actually the same as this post, though I guess I didn't need the DrawMe() call.
Lukas
Post by Lukas »
Any chance this has been updated for Moho12?
I've been using it and it's still working, but for example bone-parenting-keys don't get nudged which is a shame.
Lukas
Post by Lukas »
(Hi Rudiger, hope you're doing well wherever you are!)
I took it upon myself to update Rudiger's tool to support all new channels up to Moho 12. As this tool is very valuable to me to this day.
I've also updated the icon set with to work with the color schemes and higher resolutions:
The only thing I haven't figured out is support for channels with split dimensions. Any help with that would be appreciated.
-- Version History:
-- TODO:
   -- Support channels with split dimensions!
-- Version 1.3 (by Lukas)
   -- Added all channels up to Moho 12
   -- New icons that support the new color schemes and higher resolutions
   -- Reformatted the toolbar layout to be more user friendly
   -- Added shortcuts to tool description
   -- Disable 'selected points/bones/shapes' buttons if 'points/bones/shapes' buttons are off.
   -- Hopefully I haven't destroyed any functionality...
Download link: rt_key_tool_v1.3.zip
Hi, Lukas. Thank you very much for this, it sounds amazing.
Sadly, I'm receiving these messages in the lua console and can't make the script to work:
https://www.dropbox.com/s/0ihgd0efxu1yu ... 8.png?dl=0
Could you help me with it?
Thank you again!
Lukas
Post by Lukas »
Victor, I forgot to include the updated version of that lua file. I re-uploaded the .zip. Overwrite the files and it should work. :) Let me know if you get any errors.
Nice. Thanks, Lukas.
From a quick test, the script is working now, but I'm still seeing the first line in the lua console:
'attempt to index global "MohoMode" (a nill value)'
(I'm always paranoid I'm making a mistake here)
Lukas
Post by Lukas »
Víctor Paredes wrote: Tue Apr 07, 2020 8:00 am Nice. Thanks, Lukas.
Oh oops, that's a hook into a system we use (Made a system where the user can set Moho's into Vanilla/Animator/Rigging/Experimental-Mode to display certain sets of tools). Should have edited that out. It's harmless though, don't worry about it.
Re-uploaded the .zip again. You only have to re-import the .lua file in the tool folder. Sorry for that :)
Now it's working perfectly! Thank you very much, Lukas. It is amazing to have this updated.
Stan
Post by Stan »
Lukas wrote: Tue Apr 07, 2020 6:55 am The only thing I haven't figured out is support for channels with split dimensions. Any help with that would be appreciated.
Maybe looking at the "Iterate through all the channels in the layer" code snippet will help?
I handle those in my clean keys script: https://www.lostmarble.com/forum/viewto ... 12&t=31840
Lukas
Post by Lukas »
synthsin75 wrote: Tue Apr 07, 2020 3:37 pm
Oh that's right! I'll check out your code and will try to implement it. :)
