My Nudge Keys Toolset... Finally!!!!
Re: My Nudge Keys Toolset... Finally!!!!
The tools works no more on ASP 9.5!
Does this tool work anymore on version 10? I can't.
- Víctor Paredes
I urgently need this for version 10 too. Was anyone able to fix it?bubai wrote:Does this tool work anymore on version 10? I can't.
It would be great if you could share it.
Thank you very much.
- Víctor Paredes
Ok, I just fixed it by myself
...following this Synthsin's instructions:
viewtopic.php?f=12&t=25844
Than you, Synth!synthsin75 wrote:Anywhere you find:
table.getn(*name of table*)
Example: table.getn(tbl)
You need to replace it with:
#*name of table*
Example: #tbl
string.gfind was changed to string.gmatch
Hey Selgin,
i tried hard to fix the tool, but i wasn't as successful as you.
Synthsin´s instructions sound easy but i always get this:
Could you upload your fixed version?
i would be very grateful for your help!
rrahh
rrahh
You need to change all instances of getn as Selgin quoted above. That error says you left at least one unchanged.
Yeah! I made it!
I only changed the rt_key_tool.lua in my tool folder and forgot about the other ones in the menu folder.
Thank you!
Thank you!
Thanks selgin and synthsin75.
Rudiger, any chance of an update of the new v10(.1) channels?
I haven't looked at how this script is written, but there is now a way to count through the animation channels that would automatically catch any new channels added.
Can anyone upload the corrected script please!
Is it possible to share the corrected script for animestudio 10.1. PLEASE!!!
bubai wrote:Is it possible to share the corrected script for animestudio 10.1. PLEASE!!!
EDIT:
It is just updated "rt_key_tool_v1.2" script to work in the ASP 10.1.
No new channels are supported, like some animated layer effects, Threshold, Layer color...
Thanks a lot for the help.
Beware, it's only updated so it works again. But the new 10.1 channels are not supported. (Everything will get nudged, but the new channels will stay behind)Onionskin wrote:bubai wrote:Is it possible to share the corrected script for animestudio 10.1. PLEASE!!!
