Audio Import Problem - Help Plz
Magnitude
Post by Magnitude »
dang, it still wont work, the audio thing, i exported in audacity into a wav file and yet the song only comes up as scratching noises, and its super short
Magnitude
Post by Magnitude »
ugh, now every song i open in audacity makes the scratching sound, not much use for me
Magnitude
Post by Magnitude »
ok i found a couple that opens ok
Magnitude
Post by Magnitude »
ok im not gonna bother trying to figure out the rest till i get to that part, i got the song i needed
Check the format of the wav file that works for you.
You want to change the settings for wav export in Audacity to match those settings.
I don't know off hand what those settings are but I know if it isn't exactly correct AS has issues.
For instance I could use iTunes to convert wav files from other formats but for some reason wav format from iTunes just won't work in AS. I have to use Audacity to get the precise format of wav file.
