PARTICLEs
realsnake
Post by realsnake »
Thanks for the tutorial.. Now i'm gonna experiment it myself.
Nucleus
Post by Nucleus »
Great example Genete! this should be able to handle that dust effect more effectively. Kudos!
"Queso"
kphgraphics
Post by kphgraphics »
Nucleus wrote:Great example Genete! this should be able to handle that dust effect more effectively. Kudos!
Yes Genete thanks for a great example, i also have been trying to figure out how to do a good dust effect with the particle effects.
Genete wrote:I have no idea why at frame 31 in my case the layer doesn't follow the path (almost the last path!)
Genete, I have a feeling that it is because your "particle lifetime" is set to 30 frames...
It is not related to particles. Create a layer, move it during some keyframes, set the "Rotate to follow path" option. Then you'll see that at the last layer displacement keyframe, the rotate to follow path loose its effect. I think that AS needs almost two keyframes to calculate the "path".
