Papagayo 1.2 problems
Discuss Papagayo issues here
Lost Marble
Post by Lost Marble »
macweenie wrote: However, does capitalization count here? It usually doesn't on a Mac but this is Unix no?
PS: I re-installed version 1.1 earlier today, should I re-install 1.2 before I run the test?
No, I don't think capitalization matters here, but this is a test for version 1.2 - it won't be meaningful for version 1.1.
Lost Marble
ulrik wrote:and the "python" papagayo launched
Do you mean it launched successfully? So it runs from the command line, but not if you double-click it?
What version of QuickTime does everyone have installed?
ulrik
Post by ulrik »
Yes it actually run, I didn't investigate all functios I just tried what you said and, yes it launched
I have qt v.7.1.2
macweenie
Post by macweenie »
Okay, reinstalled 1.2 and ran test:
Last login: Wed Jul 19 18:36:56 on ttyp1
Welcome to Darwin!
Virus:~ eric$ pythonw /Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py
/Library/Frameworks/Python.framework/Versions/2.4/Resources/Python.app/Contents/MacOS/Python: can't open file '/Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py': [Errno 2] No such file or directory
Virus:~ eric$
Except for the time stamp I think the message is identical to the one I ran previously.
Oh, and QT is Version 7.1.2
Juergen
papagayo on linux
Post by Juergen »
hello,
I just tried papagayo on linux. When I start the papagayo script, I get:
/opt/papagayo/papagayo
Traceback (most recent call last):
File "/opt/papagayo/papagayo.py", line 37, in ?
papagayo = LipsyncApp(0)
File "/usr/lib/python2.4/site-packages/wxPython/wx.py", line 1951, in __init__
_wxStart(self.OnInit)
File "/opt/papagayo/papagayo.py", line 29, in OnInit
self.mainFrame = LipsyncFrame(None, -1, "")
File "/opt/papagayo/LipsyncFrame.py", line 152, in __init__
self.__do_layout()
File "/opt/papagayo/LipsyncFrame.py", line 234, in __do_layout
sizer_8.Add(self.label_2, 0, wx.ALIGN_CENTER_VERTICAL|wx.FIXED_MINSIZE, 0)
AttributeError: 'module' object has no attribute 'FIXED_MINSIZE'
regards Jürgen
bigkahuna
Post by bigkahuna »
Any update on this? I just got an iMac Intel Duo with OS X 10.4.7 and am not able to run Papagayo 2. Is there a work around to launch it?
bigkahuna
Post by bigkahuna »
Lost Marble wrote:Can you try this in Terminal?
Sorry, missed this post. This works for me. Is there a way to automate this? I'm a bit new to Macs and OSX.
Lost Marble
For any of the Mac users out there who had problems running Papagayo 1.2, please try re-downloading and re-installing Papagayo from here:
http://www.lostmarble.com/papagayo/index.shtml
I believe it may have been an installer issue that is now fixed. If you try it, please let us know the results.
bigkahuna
Post by bigkahuna »
Still doesn't work. I tried launching the icon and nothing. I tried the command line and got this:
  File "/Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py", line 23, in ?
    import wx
ImportError: No module named wx
ulrik
Post by ulrik »
Still no luck in opening papagayo, I got this when trying to open in terminal:
Ulrik-Bod-ns-dator-2:~ ulrikboden$ /Applications/Papagayo/Papagayo.app/Contents/MacOS/Papagayo
-bash: /Applications/Papagayo/Papagayo.app/Contents/MacOS/Papagayo: /Developer/Applications/Utilities/MacPython-2.3/BuildApplet.app/Contents/MacOS: bad interpreter: No such file or directory
Lost Marble
Hmm, thank you - at least now I've got some interesting error messages to use to sort things out.
macweenie
Follow-up
Post by macweenie »
Most recent from me:
Last login: Mon Aug 21 14:34:08 on console
Welcome to Darwin!
Virus:~ eric$
macweenie
Okay, wait...
Post by macweenie »
After running the command in the terminal window and getting the same error I took a good look at the syntax of the command - pythonw /Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py and it struck me that I do not have Papagayo on that path. I have a sub-folder inside of applications called Lost Marble so I can keep things neat and tidy.
I put Papagayo on the path spacified in the command line and the result I get is a simple >. No error, no nothing. I am sorry it took until now before I saw the flaw, but I am not a programmer and my mind isn't given to thinking about problems like this in such ways. :roll:
Good grief...
Ever since OSX... I have had to actually learn about... <shudder>.... directory path names in applications... ick. Don't even get me started with Flash Actionscript class paths... AAAHHHHGGG!
The Teminal scares me to death... the application not the movie.
That is a weird thing old Mac sytem 6 fans like me didn't have to deal with for a long time... that's a SIX not an upside down NINE. I still miss it... multifinder... woohoo.
Lost Marble
Alright, let's give this one more try. Mac users, please download Papagayo again and give it another try.
Sorry for all the confusion, but Papagayo is kind of a funny beast - it's written in a scripting language called Python. Python's a great language, but the combination of Mac application bundles, scripting languages, and Universal Binaries (both PowerPC and Intel code) makes for a convoluted installation. I think I've got it now - please tell me I'm right...
