Moho Pro 15 Wishes and Predictions
Re: Moho Pro 15 Wishes and Predictions
I think after experimenting more my biggest wish is still the Master Keyframe channel.
I think that's pretty difficult to implement SO as an alternative, i'd like to have just a simple, built-in, working button that shows me all the child layers of a layer with keys on it and clicking on it again un-toggles that (similar to the consolidate layer button).
I know there are scripts but with any one of them i have one issue or the other so a just nicely integrated version of this would be so neat directly on the timeline next to the push keys left/right.
Generally and i speak not only for myself here: we'd really like to see a far more simplified user experience when working with rigs that have a lot of animation on its sub-layers (old school Moho basically, bones and pushing sub-layer vectors around).
- perihelion74
I would like to see:
- better performance overall. GPU used in everything possible
- Styles complete overhaul
- Get rid of frame 0 and a separate it
- Companion Android app for drawing objects on tablets for import in the desktop app
1. A Parent Constraint/ Rivet Constraint (that works outside of a bone layer)to pin shapes to specific points of bones or shapes
2. A Freeze Transformation command like in Maya, to set every value of a shape or a layer to zero (not a reset)!
IMHO a must have for every professional Animation Pipeline Tool.
If you uncheck "Enable drawing tools only on frame 0", doesn't that get rid of frame 0 ?
Start adding the most popular scripts! It’s the quickest way to get the best results with minimal effort.
Then, keep them updated and provide tutorials.
Not only would it likely be the fastest and cheapest way to upgrade- it'd also have the most impact too!
Scripts like the MR Pose Tool and MT Transform Rig Tool would be great upgrades and easy to add.
All the scripts by Eugene Babich should be considered actually. They’ve already been proven to work well, they're very useful and very popular.
Why reinvent the wheel when someone has already done that for you..and released it and proven them to be valuable. The evidence shows that!
Not only would it likely be the fastest and cheapest way to upgrade- it'd also have the most impact.
Then scan through the rest fo the scripts and see what else could be implemented. Let the downloads guide you. The data is all there!!
threedslider
My biggest wish is to support 3D animation style, I mean import FBX or OBJ or whatever and then it supports IK/FK for 3D and so to render in Cel-shading for mixing 2D and 3D world ... That is a game changer !
Another feature is some compo need to be supported as well for 2D and 3D
Thank you to Team and to you all
A cutter tool. just like earser with zero radius but more accurate.
a tool maybe called rig set this tool behave like manipulator at frame 0 but makes changes to the rig. imagine you find that your character arm pose is not good and this tool set it like transform bone tool at frame 1.
- lucasfranca
I would like Moho to keep the last settings or have where to set up in configurations the use of animation on twos, threes, etc ...
Maybe the second option is better.
https://youtube.com/animai2D
Timeline Improvements:
A - Playhead Visibility & Focus
Make the playhead more visible, ideally with the frame count displayed.
Add a shortcut (e.g., pressing "F") to center the playhead on the screen, eliminating the need to search for it.
B - Selected Preview Area
Improve visibility by graying out everything outside the preview area, keeping focus on the main section.
C - Rewind Buttons
The rewind button should return to the first frame of the animation, not frame 0 (since we already have Toggle Frame 0).
If a preview area is selected, the rewind button should treat its first and last frames as the start and end points when rewinding.
D - Timeline Zooming
Enable easier zooming in and out within the timeline.
Additional Requests:
- I’d love the ability to scroll the timeline from anywhere on the screen by holding a key (e.g., "H") and Left Mouse Button, without needing to click directly on the timeline each time.
- Add layer-specific markers across both Sequencer and Motion Graph.
- Improve Motion Graph usability — currently, it’s difficult to identify channels and requires excessive double-clicking. A system similar to Blender's Graph Editor would be more intuitive.
Thanks!
C - Rewind Buttons
Thanks!
My Switch Icons tool lets you scrub the timeline from the workspace. If you set a keyboard shortcut for it, you can hold that key to activate the tool/scrub and release to resume the last tool.
viewtopic.php?t=34078
we should be able to patch group layers
When I open the Style Panel and load my custom color Swatches, they disappear after I close and reopen the panel.
I’d like the swatches to be saved with the project, please.
Hey. Please do Not forget that Grids. how to use that when it move rotate scale with layer? A fixed grid for all layer will come in handy.
have you tried templates?lucasfranca wrote: ↑Sat Mar 15, 2025 5:25 am I would like Moho to keep the last settings or have where to set up in configurations the use of animation on twos, threes, etc ...
