How do I roll a square forward?
Sketch_Turner
Re: How do I roll a square forward?
Post by Sketch_Turner »
Thanks for the help, guys! I really appreciate it.
Lukas
Post by Lukas »
Greenlaw wrote: ↑Fri Feb 02, 2024 3:39 pmI tried the script out briefly, and couldn't get it to work in 14.1. I'm probably using it incorrectly but maybe it's broken for Moho 14.1?
My guess is not all files are installed in the correct location, please read the instructions at https://mohoscripts.com/script/LK_Set_Origin :) I will add some pop up warnings that display "not installed correctly" with extra instructions if that's the case. It should work for 14.1
lucasfranca
Post by lucasfranca »
Lukas wrote: ↑Fri May 31, 2024 1:13 am
I did not get it: "On a switch or FBF layer the Origin is set per child layer, set the child layers' Origins from the switch level with this tool. This way you can scale and rotate on the Switch/FBF level, while each instance having their own Origin." Do you have any practical video demonstrations of using this?
https://youtube.com/animai2D
